AP1 Almost Stalling When Taken out of Gear
When I have the AC on and I disengage the clutch to stop the RPM's fall below normal idle and the engine starts to shutter as if its just about to stall. Any Ideas? This does not happen when the AC is off.
There are several things that can be causing this. Some things to try.
1. injector cleaner
2. MAP sensor whack
3. clean throttle body (I believe ckit has a thread about a groove in the throttle body where air is supposed to get to the MAP sensor being clogged, clean that)
4. replace fuel filter
5. replace MAP sensor
One of those should work. If not, a trip to the dealership is in order.
1. injector cleaner
2. MAP sensor whack
to do the map whack just take a screwdriver and flip it around then with the handle facing out tap the top of the map senser firmly a couple of times. reset the ecu then rev it up, if it starts to do it just let it fix itself. its a learning ecu so it may take a little to fully adjust
tlogic
Nov 6, 2009 11:03 AM
