Stalling.... Not map sensor
Old Sep 15, 2007 | 05:10 PM
Ogre's Avatar
Default Stalling.... Not map sensor
Allready replaced the MAP sensor but that wasnt it. I dont know where else to start looking for problems. My car has a very wierd stalling pattern. It wont stall at any speed in neutral and it will only stall once the car has come to a complete stop. I can be going 2mph and idles fine in neutral, but as soon as I stop the car will immediately stall out.
Any ideas? If you recommend the idea that fixes it $10 !!
Old Sep 15, 2007 | 09:09 PM
NVMY4N's Avatar
Look in the DIY
How to Clean IAC valve. It may help.
Old Sep 15, 2007 | 11:14 PM
s2guru's Avatar
clean the AIC, and make sure you TPS sensor has not been move.
Old Sep 16, 2007 | 05:17 AM
negcamber's Avatar
Also just check to make sure your air filter is clean. But...when you changed your map sensor, did you clean the throttle body? There is a small passage on the backside of the TB that leads air from the inlet to the map. If that passage is restricted or blocked, the map isn't getting good readings.
Disgustipated
Jun 21, 2017 02:19 PM
CTML
Oct 19, 2014 05:14 AM
Thomas Guide
Jul 13, 2011 07:34 PM
s2k bandit
Feb 8, 2010 04:03 AM
lewiS2K
Nov 1, 2009 02:13 PM
