Ap1 flywheel in an ap2 transmission
Old Jan 30, 2017 | 10:15 AM
Mijae007's Avatar
The flywheel won't allow the car to rev higher.
^ this.
Old Jan 30, 2017 | 10:34 AM
Bama Dave's Avatar
Also do the clutch delay valve delete at the same time on the 06.
Old Jan 30, 2017 | 02:45 PM
Car Analogy's Avatar
Its a resurfaced flywheel, you should get a new friction disk to go with it. When you see how much work it is to remove the trans, you'll be thinking about replacing those other parts B mentions, so you don't have to do this again anytime soon!
I was in the same boat, except my car had 75k miles, and po just had a new clutch put in. So I was just gonna wait until it needed a new clutch to go with the lighter flywheel. 'Fortunately' for me he used a crappy exedy clutch so it only lasted like 30k miles so I had the opportunity to put in the lighter one sooner than I ever thought. I went with an act 11 lb wheel. I love it. Seems perfect. I wouldn't want to go any lighter for a street car I dd. I enjoy driving the car more now. I really like how now it wants a faster shift, whereas before it really needed you to shift slower.
But, if I had to do it over again, and only had 25k miles, that would be a tough call...
Old Jan 30, 2017 | 05:50 PM
Frick26's Avatar
I really appreciate all the input. After ready the posts I think I have come up with a plan. I think I'll leave the clutch alone, but I'll get a new friction disk and new release bearings and a bearing guide sleeve.
Old Jan 30, 2017 | 09:06 PM
ES2K's Avatar
And...change to an AP1 slave cylinder to get rid of the clutch delay valve that's in the AP2 slave cylinder. Modifying your present slave cylinder by removing the CDV is also an option. Until the CDV is removed, your clutch may slip when shifting fast at red line.
Old Jan 31, 2017 | 09:37 AM
...but if you use a lighter flywheel, the effect of cdv on high rev slipping is less severe. So as an option you could leave cdv in place, try it, and if you still want to remove cdv you can.
Its easy to do cdv afterwards. Not something that needs to be done while things are apart for clutch.
youngforevers2k
Feb 26, 2018 12:52 PM
ghosta9
Feb 22, 2015 02:24 AM
mo19249
Jan 16, 2014 08:04 PM
PwetNgManok
Vancouver Island
Sep 16, 2013 10:21 AM
s2kkid05
Feb 25, 2013 09:13 AM
