AP1 S2000 Engine ticking - Stumped!!
If you really are in love with that particular car. Yes it is worth it. If you think you may sell it some day......sell it now for as much as you can. It's a lot of work. Good hobby and learning experience. You've seen my s2000 beater. I shouldn't have fixed it money wise but it is my buisness/hobby.
Why do you say that? Looks stock to me. I don't see any iron sleeve in this block. Its bone stock.
To the OP, you have to decide if the car is worth dropping roughly 4 grand into dropping in a used motor. we still don't know what's wrong with your old one. But if you are going to do it, see if you can find a 00-05 f22 engine. These are a direct swap in and can even use your ap1 ecu.
My golden eagle sleeved motor has clear support around the cylinders where the water jacket is like an entire inner new section of the cylinders/block, looks totally different then this block. I can not see where the sleeve starts/stops on the pics posted above. Just looks like a stock block to me if memory serves. Maybe the iron sleeves shown in second pic with cross hatching are considered "dry sleeve" Darton? which I'm unfamiliar with. I was looking at the entire block with coolant jacket around the cylinders which all looks the same/oem. Forged pistons are supposed to be used with an iron sleeve. Too bad if someone F that up using the stock FRM pistons. I would try and go back to that shop and have them rebuild it for free.
My Daddy taught me this - "Don't throw good money after bad." Be cautious about feeling so bad about what has happened that you make a poor decision about how to solve the problem and end up making it an even worse financial hit. For what its worth, if it were me, I think I would listen to halfassjack above. Swap in a good used engine or part ways. Keep in mind the old blue grass tune: "There's more pretty girls than one." You will find something.
BTW - I'm not sure your assumption about reliability of Ap2 engines v. Ap1 engines is accurate. Maybe - but you would have to prove that to me.
I feel very badly for you. This has been a nightmare for you.
Let us know what you decide to do.
Yep. F20 are notorious for using more oil then the F22 and that's in part to this and likely the improved valve guides on the F22, both of which are a place oil gets lost when tolerances are not up to par. Performance improvement aside, just from the longevity standpoint id run an F22.
