Ap2 diff in ap1 ?
Old Nov 27, 2011 | 02:04 AM
alricl's Avatar
Default Ap2 diff in ap1 ?
hi im considering installing a ap2 diff in my ap1. What is required to do the swap? Does anyone here know maybe Billman can chime in?
thanks
Old Nov 27, 2011 | 05:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
^ what he said.
Or you can get an AP2 driveshaft, transmission rear flange and bolts with the dif so you dont have to disturb the dif flange.
Old Nov 27, 2011 | 03:10 PM
alricl's Avatar
thanks guys do you know what the back lash & torque specs are for the diff?
Old Nov 27, 2011 | 09:39 PM
S2KPUDDYDAD's Avatar
Backlash is not set by changing the flange.
The torque load on the pinion nut needs to be a minimum of 94 foot pounds and the turning torque is 12 inch pounds. You will also want to replace the pinion nut with a new pinion nut.
The torque specs I listed are for a fresh book setup your torque numbers will vary because the rear is all together and is wet with gear lube.
You basically want a slight amount of resistance on the flange when you turn it. If you over torque the nut you will have to disassemble the rear and replace the distance piece (crush sleeve) then start over….Good luck
Old Nov 27, 2011 | 11:15 PM
alricl's Avatar
thanks mate!
yamaha6611
Mar 6, 2019 12:57 PM
grim s2k
May 16, 2016 12:01 PM
RedSunS2K
Mar 20, 2014 06:54 PM
mrscbw
Jan 15, 2009 11:02 AM
Nhan
Apr 3, 2007 08:51 AM
