Will an AP2 rear diff work in a 2000 AP1?
Old Nov 3, 2010 | 03:02 PM
grim s2k's Avatar
Default Will an AP2 rear diff work in a 2000 AP1?
Just like the title says..
Blew out my diff in my 2000 AP1.. Will an AP2 diff bolt right in?
Thanks!
Old Nov 3, 2010 | 03:25 PM
Shadow_S2K's Avatar
Former Sponsor
I believe you need to swap out the drive shafts, but other than that...it will work
Old Nov 3, 2010 | 07:25 PM
9krevvin's Avatar
Yes it will work, but you will need to swap the part that bolts to the driveshaft from your AP1 differential. If you don't the drive shaft will not bolt to the differential. Just replacing the driveshaft will NOT work!! The AP2 driveshaft will not bolt to AP1 transmission or Differential. ...Or you could swap the transmission, driveshaft, and differential.
Old Nov 3, 2010 | 07:26 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
https://www.s2ki.com/forums/index.php?showtopic=751915
Old May 16, 2016 | 07:09 AM
devildust's Avatar
Bringing it back, can someone confirm torque rating on the transmission flange nut. Also car in gear or not?
Old May 16, 2016 | 11:15 AM
Slowcrash_101's Avatar
You need to lock the transmission to install the nut, spec is 119 -> 0 -> 119 ft lbs
Old May 16, 2016 | 11:24 AM
devildust's Avatar
By lock you mean leave in gear or another way?
Old May 16, 2016 | 11:59 AM
Or lock the crank, I don't think leaving it in 6th offers enough resistance. You could use a breaker bar against the sub-frame and the crank bolt that plus 6th ought to do it.
Old May 16, 2016 | 12:01 PM
devildust's Avatar
Ahh yes I was actually thinking about that, thank you.
Nero_slk
Nov 3, 2015 02:35 AM
lopez14
Oct 20, 2012 11:34 PM
mrscbw
Jan 15, 2009 11:02 AM
kfdon
Jun 28, 2008 04:33 PM
Nhan
Apr 3, 2007 08:51 AM
