Ap2 overrev?
Old Jan 5, 2007 | 08:05 AM
s2k dre's Avatar
Originally Posted by steven975,Jan 4 2007, 08:03 PM
yep, the longer rods are are a real factor.
Honda, if they wanted to do it right, should have made the block about 10mm taller to keep the rod length up...but obviously that would require a new casting, new mounts, etc.
the rods are same, i think just the crank gives it a longer stroke.
Old Jan 5, 2007 | 07:15 PM
srl311too's Avatar
Have you ever done a search on this site? You get a kazillion responses to a search like, "ap2 overrev". Just looking for a little guidance or a linky to assuage my parinoia over the overrev. Now, every small engine noise screams to me BOOM!!
Thanks for the positive responses.
Old Jan 5, 2007 | 08:10 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'd personally be amazed to see a stock AP2 break a retainer, and not show other symtoms from bent valves.
Old Jan 5, 2007 | 08:12 PM
nrgizeman's Avatar
i over rev to 9500rpm. fully checked out and no damage. thank god~!
Old Jan 5, 2007 | 08:14 PM
Billman250's Avatar
Top Answer: 1
So how about that theory
You tell me yours, and I'll tell you mine on the reason Honda went to 2.2L.
Old Jan 5, 2007 | 08:23 PM
Slows2k's Avatar
How do you know you only saw 9500?
Old Jan 6, 2007 | 08:11 AM
Ch0pper's Avatar
Old Jan 6, 2007 | 12:00 PM
steven975's Avatar
Originally Posted by sexycheto88,Jan 4 2007, 08:12 PM
well they could of just easily increased the bore. and strengthen the rods to compensate for the aditional wieght and pressure and i think they could have kept the same redline.
the bores are already almost siamesed. I don't know how they would bore out more than a mm or so without going into the next cylinder!
Old Jan 6, 2007 | 12:03 PM
steven975's Avatar
wrong, the rods have to be shorter to compensate for the increase in crank diameter.
the distance between the piston's TDC and the crank's centerline have not changed.
The only way you could use the same rods is if the block were taller to compensate for the crank's change in dimension. It isn't.
yamaha6611
May 24, 2017 02:13 PM
starrman
Oct 6, 2012 02:27 PM
hondaf1
Dec 24, 2009 05:30 PM
boostingdsm
Oct 17, 2006 01:57 PM
