Ap2 tranny in Ap1 HELP !
Old Sep 20, 2011 | 03:55 AM
s.french's Avatar
Default Ap2 tranny in Ap1 HELP !
Hey guys,
I know there is alot of topics on that but I can't find the answer i'm looking for .
I just bought an AP2 tranny for my 00 Ap1 S2000.
What is the mods i have to do to make it fit ?
Can someone tell me the exact part numbers i need ?
Thanks alot !!!
Old Sep 20, 2011 | 05:03 AM
Stratocaster's Avatar
You need to remove the output flange from the ap1 tranny and install it on the ap2 tranny.
Old Sep 20, 2011 | 05:53 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Your speedo will also be a little off.....yellow box install will fix it. But yes rear flange swap and that is it.
Old Sep 20, 2011 | 07:07 AM
TougeS2k's Avatar
Damn, is this flange easy to replace? If so this sounds like a MUST DO upgrade for any older AP1 with clunky/chunky or sticky trans issues. I see Ap1 MT for like $500, are the Ap2 generally more?
Old Sep 20, 2011 | 09:30 AM
s.french's Avatar
Thanks guys, would you have any parts number? I'm a real newb at it haha.
TougeS2k, i'm in Canada and had a pretty good deal. 1000$ to my door!
Old Sep 20, 2011 | 10:40 AM
Billman250's Avatar
Top Answer: 1
you dont need part numbers, there's nothing to buy. Put your ap1 flange on your ap2 trans.
Old Sep 20, 2011 | 01:22 PM
s.french's Avatar
Billman250, i don't have to change bolts nothing ? Found that on a topic...
40441-PCY-A00 FLANGE, COMPANION $35.49 $35.49
91201-PCY-003 OIL SEAL (40X60X9) $5.64 $5.64
91005-PCY-003 BEARING, BALL (31X55X13) $13.08 $13.08
91302-PCY-003 RING, BACK-UP (28MM) $2.09 $2.09
95701-08040-08 BOLT, flange (8X40) $0.70 $0.70
90402-PL9-000 WASHER, SPRING (27MM) $3.21 $3.21
90203-PCY-000 NUT, HEX. (27MM) $3.02 $3.02
Are that parts I have to buy ?
Thanks !
Old Sep 21, 2011 | 08:54 AM
hypforlife32's Avatar
I have a question about this too, not trying to thread Jack but do you have to pull the transmission apart or is it just one big nut on a shaft type deal? Like a 10 min job or 2 hour job?
Old Sep 21, 2011 | 09:23 AM
GyozA's Avatar
More like a 4 hour job if you know what your doing.
Old Sep 21, 2011 | 11:07 AM
speedjunky01's Avatar
thanks for the info the shorter gearing and the longer 6th along with less clunking sound like a nice upgrade to my car, the shift to 2nd on the MY00 leaves something to be desired
