axle nut TSB question
Just wondering if its safe to loosen and tighten the axle nut while both back wheels are off the ground with the e brake on and car in 1st gear? Thats how i did mine so i just wanted to make sure i didnt mess anything up because the axle nut still makes the popping noise now. i was only able to make the nut about go from 12 to 1 oclock maybe its not tight enough? Or should i just assume its the hub and bearing at this point.... Also i only get the popping noise in reverse when the car hasnt warmed up yet. Thank you
little Chris
Jun 5, 2006 05:30 AM
wantgoback
Apr 2, 2003 03:39 AM
