axles worn?
Old Jan 5, 2008 | 05:44 PM
m1northreat's Avatar
Default axles worn?
so my s2k is lowered and i knew that it was wear out my axles prematurly. im gettin more noise from my rear end now and i was just wondering how long i can drive on them this way and when do i know that they are BAD.
Jairo j
Old Jan 5, 2008 | 06:52 PM
negcamber's Avatar
Just swap the cv buckets from driver's side to passenger side and vis versa. Your axles should be ok.
Old Jan 5, 2008 | 09:42 PM
iam7head's Avatar
what type of noise?
scraping? clunking?
Old Jan 10, 2008 | 12:24 PM
ZDan's Avatar
I'm getting a scraping/creaking/light-grinding noise from my rear halfshafts (sounds like). Only at neutral throttle. Under positive or negative load, no noise. Cornering loads subdue the noise as well. Almost sounds like a halfshaft lightly grinding on a sway bar.
It doesn't make the noise all the time, but seems to be doing it more so here lately (despite my hopes of it going away!).
I'll be bringing the car into my work to have a look in a bit, anything in particular I should be looking for?
Thanks!
Old Jan 10, 2008 | 04:23 PM
negcamber's Avatar
Reminds me of the sound my wheel bearings made when they started going bad. Scraping sound that would go away in corners...it turned into a screetch after I ignored it for a couple more weeks.
Old Jan 10, 2008 | 05:32 PM
RED MX5's Avatar
Yea, Negcamber, "grinding" sounds more like wheel bearings than CV joints.
Old Jan 10, 2008 | 06:21 PM
ZDan's Avatar
Thanks for the input!
I got under the car earlier this evening, and it seems like it might be diff output bearings (I made another thread about it)
I could grab the inner cv joint and move it up and down a bit, thought it must be the CV, but then I noticed that the diff output flange moving relative to the diff, up/down maybe ~.015" and visibly wiggling (top of flange in/out, bottom out/in). Both sides, left a little more.
I'll investigate wheel bearings tomorrow. When I tried to rock the wheels back when I first noticed the scrapy noises last month there didn't seem to be any play.
I drive like a grandma on the street, but of course drove the bejeezus out of it at the track this year. 10 track days worth.
Thanks again, additional thoughts/commentary/advice appreciated!
Old Jan 11, 2008 | 04:53 PM
ya im gettin the same grinding sound on occasion. comes and goes
mcdizzle
May 1, 2013 07:21 PM
TJ01s
Aug 20, 2008 05:30 PM
taffyb
Dec 4, 2007 04:03 AM
taffyb
Oct 12, 2007 09:35 AM
s2kntx
Oct 6, 2007 09:49 AM
