bad 02 sensor?
Old Jul 16, 2007 | 11:40 AM
S2LEZZY's Avatar
Default bad 02 sensor?
Hey guys
Any Help will be great ...
I got this code PO133 the "02 sensor slow to respond. (bank 1 sensor 1)."
Primary sensor and its gotta be shot. Right?
I also pulled this code P1129. "Manufacturer controlled fuel & air Metering"
Guessing this code (P1129) is caused by the faulty 02 sensor?
Is it a good idea to replace the 2nd 02 sensor at this time? got smog this year.
yes its been running poopy. i thought it was the map, did the wack when it originally acted up, before i got the codes.
also the spark plugs look as if shes been running a little lean.
the S is an 03 w/ 27k miles on w/ comp T supercharger after cooler.
Thank you
Old Jul 16, 2007 | 06:23 PM
ridestrt's Avatar
Hm thats strange. Usually when an 02 sensor dies the ecu makes it run pig rich to keep you running safe. You don't need to replace the secondary sensor if you don't want to, if its working its working.
Old Jul 16, 2007 | 08:24 PM
gomarlins3's Avatar
Do you have a TP as well?
Old Jul 17, 2007 | 03:14 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
P1129 is high MAP signal.
Old Jul 18, 2007 | 08:30 AM
S2LEZZY's Avatar
Hi...
Ridestrt- i thought so also, ill ck the plugs again mabie things have changed.
Marlins- nope, no TP here, live in the nazi state of CA. They'll hang me!!!
Billman - would it be best to buy a new map or just beat it again? Also what do you refer to as high? it just reads high and it needs a reset?
thank you for ur insight
s2knOOb02
Jan 17, 2008 08:06 PM
Kenpo_S2000
Jun 12, 2007 06:12 PM
Kenpo_S2000
Oct 9, 2006 07:19 PM
