bad ecu
Old Dec 24, 2012 | 01:57 PM
jays2k24's Avatar
Would I have to re program my key to ecu when installing new ecu ?
Old Dec 24, 2012 | 03:27 PM
JUSTINTHECOASTIE's Avatar
Did you check your battery?
Old Dec 24, 2012 | 03:41 PM
Kalibos's Avatar
[quote name='jays2k24' timestamp='1356383688' post='22228255']
I had my mechanic check voltage on ecu he told me it was low but want to make sure that's actually the problem
[/quote
What's "Low" voltage? Should read 12-12.5 VDC with the car off. Anything less that indicates a voltage problem which typically is a bad battery and/or a grounding issue. With the car on you should read anywhere from 13.5-15 VDC. Anything less than that indicates a bad alternator. A low voltage that would cause problems with the ECU would probably be somewhere <11VDC range. Are you experiencing any other electrical problems like dim lighting or the engine not turning over as fast when you attempt a start?
v/r
James
Old Dec 24, 2012 | 05:41 PM
Ultimate_Combination's Avatar
$200 for an ECU? What are you in AUS?
I just so happen to have a good ECU removed at 60K from my 2001 which I can let go for $90.00 plus shipping.
Yes, you're going to have to get the car to the dealership to get the keys reprogged.
jays2k24
Dec 25, 2012 02:51 AM
AndyS2
Oct 16, 2003 11:14 PM
RARE M5
Apr 30, 2003 01:45 PM
