best place to run wire into the cabin
i'm installing a wideband and looking for a good place to run the wires from the sensor into the cabin. i looked around but didn't see and place that have easy access. please give me some recommendation. thanks,
The "best" place I found was at a grommet in the driver's foot well that has the ecu wire bundle headed to the engine compartment. You may have to make a small slit in the rubber to get the head of the wideband plug through...so far no problems from the incision.
if your installing a wideband then running through the grommet behind the batter makes more sense since its on the side of the exhaust. Its also easier to access if you pull the battery.
[QUOTE=negcamber,Jun 7 2008, 07:35 PM] The "best" place I found was at a grommet in the driver's foot well that has the ecu wire bundle headed to the engine compartment.
