Billman's Brake Fluid Gravity bleeding revised
Old Oct 19, 2014 | 07:27 AM
  #71
S2Ko0o's Avatar
I am going to give this a shot over the winter vs the traditional 2 man, thanks for the info!
Old Oct 19, 2014 | 07:37 AM
  #72
Stunn-3-r's Avatar
Maybe I'm wrong, but couldn't you still see the change in fluid color from old to new while bleeding?
Old Oct 19, 2014 | 07:40 AM
  #73
Slowcrash_101's Avatar
You could just use a pyrex and measure out 150 - 170ml of fluid, on average that's how much I bleed from each caliper before it turns clear. Volkswagen trains their techs to empty 500ml of fluid from each wheel brake which is total overkill.
Old Oct 19, 2014 | 07:53 AM
  #74
cdubea's Avatar
That's good info. I'm putting together an extensive list of maintenance to do before I put the car up for the winter and this is on the list.
Cheers,
Chris
Old Oct 19, 2014 | 07:54 AM
  #75
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
1/3-1/2 pint out of each wheel is all you need for it to turn colors. So if you do 1/2 pint on each wheel, you're good.
Old Oct 19, 2014 | 09:05 AM
  #76
All respect to you billman, I think that's overkill personally. That would mean you need two one-liter bottles(the tall ones) of brake fluid just for brakes, I usually go through a 1 liter bottle of brake fluid per flush, with clutch hydraulics included. That's with emptying both reservoirs topping them off bleeding and re-filling after each wheel and clutch master. I mean it certainly wouldn't hurt if you want to be thorough, but I can't justify $45 - 50 worth of brake fluid to do a simple flush. Less so if you do it at least once a year. Tracking your car is probably a different story, you gotta pay to play and I understand that.
Edit: Whoops, I forgot there's 2 pints per liter, damn dyslexia.
Old Nov 2, 2014 | 09:47 AM
  #77
bgoetz's Avatar
Anyone have any thoughts on speed bleeders using the gravity system? My thought is that they won't work. I am replacing all of the calipers and the old ones had speed bleeders, I am just trying to decide if I want to swap them over as well.
Just answered my own question, seems the speed bleeders suck (they came with the car and I have not used them yet) and based on how they work I don't think they would work for Gravity bleeding, so they will stay with the old calipers
Old Nov 2, 2014 | 08:32 PM
  #78
windhund116's Avatar
Can ATE Super Blue Fluid be imported from Germany? If not, I presume the ATE TYP 200 DOT 4 (yellow) will work fine. Since yellow/amber fluid is the only one available, is OEM Honda DOT 3 or 4 just as good? Or stick with the German stuff?
Much thanks!
Old Nov 2, 2014 | 11:39 PM
  #79
alSpeed2k's Avatar
^You can come buy it in Canada, lol! But they've jumped in price a lot!
Old Nov 3, 2014 | 01:24 AM
  #80
Just use the amber stuff, no biggie, just use a little less than half a pint on each wheel.
