Bilstein PSS9 Question
May 29, 2007 | 03:53 AM
Hey guys,
I just installed the Bilstein PSS9 coil overs on my 04. They dropped the front 5/8" and the rear 1 1/8". That was at the middle of the shock settings. After installing them, I had the car aligned. In the rear, one side maxed out the camber adjustment at a minimum of 2.7 degrees. The other side was around 2.4. Is there any way to lower those numbers? Do I have anything to worry about when running that much camber? I'm thinking about raising the rear another 1/4" or more to try to decrease the camber. Thanks.
Tim
Reply 0
May 29, 2007 | 07:29 AM
Generally dropping cars will increase camber. If you want less you'll likely have to raise it up or get longer upper control arms.
Reply 0
