bizarro power loss/sputtering issue
Old Nov 12, 2016 | 11:28 AM
speakeasy2009's Avatar
Originally Posted by Spartarus
You can get away with driving on a bad #2 sensor forever, because it's only there to monitor the cat. It doesn't affect anything in the engine.
The #1 sensor is used for closed-loop fuel correction. The car only runs in closed-loop fueling above a certain coolant temp. That explains why it only happens hot. Running cold, the engine will run fine. Once it gets to operating temperature, and starts reading the (bad) O2 sensor to fine-tune fueling, the car runs like crap.
Replace the front O2 sensor. The problem will go away.
Thanks a lot. Any trick to getting this o2 out or its pretty straight forward? I havent even looked to see where it is yet but i assume its under the manifold cover, Its been in the car 15 years so im gonna assume right now it wont come out without some heat and/or leverage.
Old Nov 12, 2016 | 12:43 PM
Slowcrash_101's Avatar
The hardest part is undoing the electrical connector because it's obscured by the transmission. They're all pull tabs.
When you remove the sensor from the exhaust, don't crank on it, get the longest wrench you can find I think it's a 7/8ths, and just give it a quick whack.
Old Nov 12, 2016 | 12:52 PM
Originally Posted by Grilla
https://www.obd-codes.com/p0410
Says right there that it causes hesitation on acceleration. I think maybe your car is running too rich and is choking on fuel. Your dead primary O2 may have been a direct result, but definitely now you're not running in closed loop (self-corrected AFR) and having a CEL you have way too much fuel. Fix the codes now or pretty soon your cat will have an issue, too.
Secondary air injection doesn't cause any hesitation as the air-pump does not work while the car is at operating temperature. The air pump only works on cold starts to aid in emissions burn off and to help the catalytic converter come up to temperature.
The cat and O2 sensor won't work until exhaust temperature is roughly 600F at the end of the exhaust manifold, ideally for it to work at it's most efficient exhaust temp should be ~800F.
Old Nov 12, 2016 | 06:40 PM
Spartarus's Avatar
Yes. PB blaster is helpful.
Otherwise, 50/50 mix of Acetone and Automatic Transmission Fluid. Don't ask me why that works, but it works so well that I can remove rusty-ass 18-year-old exhaust bolts with a 1/4 drive ratchet.
Here's a shot from the FSM detailing the location of the parts in question.
...I guess you click to expand...? Tell me if the image isn't working.
Attached Thumbnails bizarro power loss/sputtering issue-replace-pri.jpg
Old Nov 12, 2016 | 11:21 PM
MorngWoodStewie's Avatar
Whenever I remove o2's I warm the car up well. Get it hot and it should break loose. Piece of cake
Old Nov 13, 2016 | 06:10 AM
Thanks a lot guys for all the input. Any suggestions as to where i can find the upstream o2 for the best price? Dealer price is crazy..
Old Nov 13, 2016 | 07:59 AM
Spartarus's Avatar
Rockauto
There are many options from Rockauto. Denso is the OEM supplier, Bosch would be second choice if you're really strapped for cash. Don't bother with any of the other brands.
Denso is $92, Bosch $35.
Old Nov 13, 2016 | 01:19 PM
Thanks man the image works, but thats the downstream sensor. Mine is bank 1 circuit 1 so isnt that one in the manifold??
Old Nov 13, 2016 | 02:10 PM
Spartarus's Avatar
Ah, that's a combination picture.
The first picture shows both sensor plugs on the left side, that's what it's meant to illustrate. It's a drawing from behind the transmission mount, so the Downstream sensor is also pictured in the frame, but that's just a conincidence. It's not the focus of that picture.
The second picture shows the upstream sensor (in the manifold) with a wrench on it. That's the sensor you remove. Hence the cartoon wrench.
Those cartoon drawings are not always perfect, or easy to understand.. That is the factory manual though, not some 3rd-party manual.
Old Apr 2, 2017 | 05:33 PM
thegolffather's Avatar
After reading thru this thread am I correct to conclude that without a dyno and a tuner installing an itb system would be a waste of resources? Thanks
black_EM1
May 13, 2016 07:53 PM
s2000_sk
Aug 2, 2009 12:07 AM
s2jeezy
Dec 12, 2008 01:23 PM
s2kdriver80
Dec 7, 2008 10:49 PM
aguilars2k
May 16, 2006 12:57 PM
