boot from spark plug plate
Old Oct 16, 2015 | 12:03 PM
s2kbtos's Avatar
Default boot from spark plug plate
One of the bolts on the spark plug plate is all rounded and can't get it out. I have tried a bigger size torx tool and allen. Nothing.... do you guys recommend anything to get it out????
Old Oct 16, 2015 | 02:33 PM
steven975's Avatar
dremel notches and use a big flathead?
That is a 9 lb-ft bolt. I'm not sure why it rounded off.
Old Oct 16, 2015 | 07:01 PM
s2kbtos's Avatar
I don't know either.. but I have to try that.. I don't know how else to get it off.
Old Oct 17, 2015 | 08:58 AM
Chuck S's Avatar
Many (most?) folks pay no attention at all to torque requirements and don't even own a torque wrench.
Try using a Torx (sic) bit. <------ That's a link!
Buy new bolts. Tighten to proper torque.
-- Chuck
Old Oct 17, 2015 | 10:14 AM
Car Analogy's Avatar
They have these drill bit screw remover tools. Its a hardened bit, with a tip that has a tapered, reverse thread. Its made to bite into a stripped philips screw head. Would probably work well for stripped allen or torx as well.
Its about the size and shape of a philips drill driver bit, except as mentioned, its got a tapered cone shaped head, with these really small reverse screw threads.
So as you drive it in loosen direction with drill, it bites into stripped head. The more you push, and loosen, the more it bites.
Can get from Home Despot, etc.
Sent from my SM-G920P using IB AutoGroup
Old Oct 18, 2015 | 09:37 PM
s2kbtos's Avatar
I tried that method showed on the video, but no cigar... also, went to home depot to buy the "speed out" removal kit and the same.... no luck. I guess I will have to take it to a mechanic that can remove it for me.....
daileyboy81
Oct 1, 2014 07:27 AM
Kenshyn
Jan 17, 2012 11:33 AM
DJT
Aug 20, 2010 02:22 PM
superman6074
Mar 9, 2008 03:10 PM
Prancing Horse
Mar 21, 2004 04:00 PM
