Brake Fluid Change? Ss Lines? Tutorial?
Is there a Brake fluid change Tutorial that I'm not seeing somewhere on this site? I need to install these SS brakelines that have been laying around my house for some time now but have never messed around with brake systems other that just the pads.
Is it just a sinple Take off old brake lines,
let the fluid run out,
install new SS brake lines,
Add brake fluid ,
and bleed.
Is it that simple? Or what do I need before I do it?
Oh yeah, I'm putting in ATE Superblue fluid.
Thanks
Add brake fluid ,
and bleed.
Thanks
it's pretty much as what you said and xviper's. but turning the nut on old hose on reservoir weren't easy. you'll need proper tool. I believe 10 mm open wrench, one that grap like 5 side of the nut. I didn't know where it was so I had to use vise grip.. also, take out the clamp that holding that nut AFTER you loosen the nut.
one more advise. two person makes it a lot easy to bleed the brake.
Ok cool,
About the bleeding, I was thinking about getting a powerbleeder. You can bleed them yourself with one of them , correct?
If so, any recommendations on a decent inexpensive one?
Originally Posted by J.T,Jul 7 2004, 11:19 PM
Ok cool,
Administrator
