Brake Light / Cruise Control
Had a question.
My Emergency brake light stays on even when the E-Brake is not engaged.
I believe this to be the reason why my cruise control isn't working.
Anyone have any ideas or suggestions?
Thanks in advance.
Thanks in advance.
Low brake pads will trigger a dash light?
The brake fluid seems fine.
I was thinking that the light is connected to the cruise control problem, since when the brakes are "on" cruise control deactivates.
that's odd...it sounds like you may have 2 separate issues.
the brake light can stay on even with the reservoir full if the float that senses low fluid gets stuck in the low position. check to see if it's at the top where it should be.
as far as the CC...
no idea
as far as the CC...
no idea
A sunken brake reservoir float is a fairly common S2K failure.
