Breather filter
Old Apr 22, 2009 | 03:48 PM
Boofster's Avatar
Default Breather filter
I know many are running breather filters.
All I can find in ~1/2" flange (front valve cover) is K&N part 62-1340.
But it seems it doesn't have enough neck.
Please post up what other options you have found.
Old Apr 22, 2009 | 11:36 PM
terahertz's Avatar
ive seen people use a bit of hose and clamp on both ends
Old Apr 23, 2009 | 05:58 PM
Boofster's Avatar
bumpitty?
Old Apr 24, 2009 | 10:11 AM
siik_ap2's Avatar
not sure what you are asking...post up an example pic..
Old Apr 24, 2009 | 04:41 PM
SgtB's Avatar
I just see them as one more filter to keep clean. The stock configuration just uses the main intake filter.
Old Apr 24, 2009 | 04:47 PM
Stratocaster's Avatar
I just bought the cheap one they had at the autoparts store. It came with the small section of hose and a clamp. It was a PIA to get on the valve cover but I don't think it will come off too easy.
Old Apr 24, 2009 | 08:17 PM
Boofster's Avatar
A better question:
Is it ok to run both outputs of the valve cover to one catch can?
Old Apr 24, 2009 | 10:47 PM
SgtB's Avatar
The breather needs to be to atmosphere, and the pcv to vacuum, so not really. You could run them both to a vented can, but you'll be defeating the PCV system. It's neither bad or good,depending on what you want, but that's what it will do.
Old Apr 25, 2009 | 12:20 AM
Boofster's Avatar
PCV is just for emissions right?
Yes running to vented can with FI.
I think I'll just run both to it rather than adding a breather on the front of the valve cover itself.
Old Apr 25, 2009 | 04:47 AM
siik_ap2's Avatar
so removal of the hose from valve cover to intake arm and installing a filter on the vslve cover shjouldnt cause any harm correct?
Competitor9
Jun 20, 2010 03:34 PM
siadam
Oct 9, 2009 03:10 PM
gumbey75
Apr 23, 2009 08:14 AM
DDonovan
Feb 18, 2009 08:33 PM
SkitZo
Mar 11, 2001 06:40 AM
