it broke again :(
So I had this compression problem from an overrev, took the whole thing apart, replaced the head gasket w/ a spoon one and upgraded the exhaust valve springs. Everything was super. she ran great, sounded great, it was great. The other day I heard some nasty noises at redline. Check the vafc, somehow it was trimmed to -50 at redline and -10 just before vtec. i.e. the rightmost setting on wide-low and wide-high got bumped WAY too low. put it back where it's supposed to be and reset the ecu.
Now, everything feels normal again except when I go thru vtec crossover and towards redline...she doesn't want to rev past 8500. In third gear she physically WON'T go past 8500. not rev limiter style, it just can't make it. wtf?? power delivery is perfect everywhere in the range except those two spots. Zeroed out everything on the vafc, same deal. ideas?
omg i had the same problem but no vafc, this is how i fixed it, not sure what thing i did fix it though but heres alll i did
filled oil (extremely low)
tapped map sensor to death
checked all vacuum hoses and even replaced one
reset ecu
changed plugs
like i said not sure what fixed the problem because i did all this at once but it runs great now!
reset ecu
changed plugs
