Broken E brake handle. How to remove?
Old Feb 9, 2022 | 02:24 PM
Ctheodores's Avatar
Default Broken E brake handle. How to remove?
I purchased a s2000 Renegade parking brake button and when I went to install I turned the wrong way on the e-brake button.
I ordered a new e brake off EBay but can’t find any good videos on removal/install of a new e-brake. Anyone have a good video or detailed steps on how to put the new one in?
Old Feb 10, 2022 | 09:07 AM
Chuck S's Avatar
No hints in the Service Manual?
You have the installation guide?
-- Chuck
Old Feb 10, 2022 | 12:43 PM
jimmyfu's Avatar
I had this happen to me. I don't remember it being that hard. Take off the center console, and you should see one bolt ( i swear I thought it was two but diagram shows only one) holding down the lever to the body. Disconnect the lock pin from the old one as well so you can remove the cable mechanism, and then reinstall in reverse order. Make sure to chock the tires in both front and reverse directions, as you'll probably be working with the parking brake disengaged, and the shifter will probably be in neutral so you can take off the center console.
Old Feb 10, 2022 | 04:01 PM
windhund116's Avatar
Great advice, re: chocking the wheels (the front and back of at least one tire).
Old Feb 15, 2022 | 03:35 PM
Ctheodores's Avatar
Thanks for the help. Wasn’t bad at all
Headchef
Jan 31, 2009 09:58 AM
shotiable
Feb 13, 2008 06:20 PM
pjkwong
Jun 12, 2003 05:30 AM
The Reverend
May 29, 2003 07:30 PM
yogi
Nov 5, 2000 06:33 PM
