Bucking and "ticking"
Not a mechanic at all so please no laughing. anyway under low acceleration around 3k - 4k in the rpm range the car will buck a bit in first or have this feel of power loss in the higher gears. also when i slip the clutch into 1st i hear this metallic clicking noise when the 1st engages. Bought the car used at 50k and now has 75k miles on it any help would be awesome.
thanks
-j
thanks
-j
the metalic clicking is probably your synchromesh gears. If you haven't changed the tranny fluid do so, that's a good place to start and see if that quiets it down.
The other issue could be a several things but I'd be looking at cleaning your injectors and checking your plugs.
good luck
fltsfshr
good luck
fltsfshr
stryder9
May 3, 2005 05:04 PM
