Burning Lots of Oil
Old Apr 10, 2005 | 04:42 PM
Riceball's Avatar
Default Burning Lots of Oil
Hey guys I have a 02 and i recently had the motor bebuilt because i mis-shifted. It was done by a very reputable shop. Anyways it has about 7000 miles since the rebuilt and seems to be burning lots of oil. The last oil change was about 1500 miles ago and it burnt around 2 and 1/4 quarts. Is this normal or should i take it back to the shop. What could cause this and i see no oil leaks.
thanks Jason
Old Apr 10, 2005 | 10:47 PM
S2kracka's Avatar
You should go talk to the shop who did the rebuild, 2.25 qts of oil is excessive for 1500 miles unless you were driving the car REALLY hard.
Old Apr 11, 2005 | 01:57 AM
honda9krpm's Avatar
what oils have you been using and when was that changed?
Old Apr 11, 2005 | 08:41 AM
Wisconsin S2k's Avatar
Yeah even for our oil happy cars, that seems excessive.
Old Apr 11, 2005 | 08:51 AM
rworne's Avatar
Mine would do slightly more than 2 quarts in a 3500 mile oil change cycle. This time around, it's done a quart (actually 1000ml) in less than 1500 miles.
Old Apr 11, 2005 | 11:03 AM
slalom44's Avatar
Top Answer: 1
How extensive was the rebuild? Did the shop hone the cylinders? New rings? This might be contributing to the oil consumption, especially if you've been VTECing the engine.
Personally, I think that 2.25 quarts in the first 5500 miles isn't excessive on a newly rebuilt engine. That's not excessive even on a fully broken in engine.
Old Apr 11, 2005 | 09:29 PM
Riceball's Avatar
The rebuild included new pistons (Arias), sleeves, valves, valve guides, retainers, etc. etc. So far i put about 6-7k miles since the rebuilt. The last time i changed the oil was about 1500 miles ago with castrol gtx 10w30 and oem filter. I checked the oil yesterday and it took a little more than 2 quarts to fill it back up. I hit vtec a couple times a day and drive a little agressively.
Thanks for all the help!
Jason
Old Apr 12, 2005 | 12:52 AM
honda9krpm's Avatar
so are you saying that you did not change oil until 5.5 k miles after rebuild? What oil did the shop use initially? Was run in oil used at all ?
Old Apr 12, 2005 | 04:37 AM
yakrat's Avatar
What is the compression ratio? Do you have a turbo/supercharger on it? If so, was it on during break-in? How did you break-in the motor? What oil did you use to break-in the motor?
CoralDoc
Mar 27, 2018 01:01 PM
gregor_konstantin
Nov 27, 2012 05:04 PM
JROSEN
Apr 11, 2005 11:14 AM
GundamZ
Aug 7, 2002 12:17 AM
s2ktaxi
May 14, 2001 06:02 AM
