Busted Differential Mount 2000 S2000
Old May 21, 2011 | 06:26 AM
Tennisjon2002's Avatar
Default Busted Differential Mount 2000 S2000
I have a 2000 S2000 with a busted differential mount. How bad is it to drive on it for a while? Is this something that should be replaced sooner than later or is it something that can wait until there is other work being done in the differential area?
Old May 21, 2011 | 07:35 AM
downloader's Avatar
you diff will move around, soon the seals will leak and you will run out of oil
Old May 21, 2011 | 09:04 AM
Stratocaster's Avatar
E mounts can be bought cheap used. I know I have at least three sets I would love to sell.
Old May 21, 2011 | 01:56 PM
SgtB's Avatar
Cut bothe ends off, leaving the center webbing, and clean it out. Use window weld to fill it. Works great.
Old Jun 5, 2011 | 07:12 AM
So this is something I should get fixed and not something I can ignore?
Old Jun 5, 2011 | 08:15 AM
robrob's Avatar
Yes, an easy fix that if ignored will lead to a very expensive fix.
Old Jun 8, 2011 | 04:26 AM
HMFIC's Avatar
Absolutely. As a matter of fact, one of my mounts busted and it leaked fluid. When i would take turns it would hit the exhaust. I went and bought the EVS diff collars and i just replaced them last night. There is ZERO movements now and i highly recommend them.
THIS!!!
Old Jun 20, 2011 | 06:56 PM
I am going to get this fixed. Isn't it the rear drivers side (left) mount that always goes out?
What parts would I need?
http://www.hondaautomotiveparts.com/...ERENTIAL+MOUNT
is it just the rubber part I need?
Old Jun 21, 2011 | 06:38 AM
SgtB's Avatar
#2 is passenger, #3 is driver. All you need is the mount itself.
hawkman199
Sep 4, 2015 06:09 AM
dbg2
Jul 16, 2012 01:36 PM
newchapter
Oct 10, 2011 03:34 PM
mistaXs2000
Aug 2, 2008 12:05 PM
David1
Aug 3, 2003 03:30 PM
