Cam Cap Broken!
Old May 10, 2025 | 10:12 AM
DuncansS2k's Avatar
Default Cam Cap Broken!
Yr2000 number 5 cam cap broken.
150k miles.
Where from here guys? Order matching set and replace? Anything else to do while I’m at it?
Thank you in advance for any help. Very appreciated!
Cam cap 5 broken. That was the reason sensor was worn.
Sensor B with worn groove.
Old May 10, 2025 | 11:43 AM
B serious's Avatar
Yeah, you'll want to buy the whole cam tower set.
Check the cam for wear too.
Old May 10, 2025 | 12:49 PM
zeroptzero's Avatar
I've never seen much information about these kinds of failures, but you want to explore the potential cause as much as you can. Finding replacements is hard, you don't want it to happen again.
Maybe check the screen on the vtec solenoid and make sure it isn't plugged with any kind of debris ? causing oil starvation issues . Unless the cap was over-torqued in recent times if someone worked on the engine. just guessing.
Old May 10, 2025 | 01:46 PM
noodels's Avatar
pps
lets keep posts in same place
Cam Cap Broken! - S2KI Honda S2000 Forums
Old May 10, 2025 | 02:42 PM
windhund116's Avatar
My guess is that it was an improper torque sequence during the last tightening.
Old May 11, 2025 | 11:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That happened from running a long period with 0 oil pressure. Note the overheating and burning of the cams.
Loose camwheel bolt is the number one cause. As soon as that bolt becomes loose, oil pressure bleeds off from the camwheel into the chain case, starving the top end.
Old May 11, 2025 | 02:13 PM
Car Analogy's Avatar
Dang
I recall reading a thread many years back about retorquing that bolt. Make sure it hasn't backed loose.
I took that suggestion. Loosened it, retorqued it.
Now I know the consequences.
Old May 17, 2025 | 08:03 AM
DuncansS2k's Avatar
Thank you for the response.
Cams and Caps (full set of 10) just came in. Back off cam wheel bolt and retorque to spec?
Anything else I should do? Planning to adjust valves.
Old May 17, 2025 | 09:32 AM
Slowcrash_101's Avatar
Back off the valve adjustment screws all the way, set valve lash after tightening the cam caps. Pressure from the valve spring can put enough tension to crack a cap.
Old May 17, 2025 | 01:45 PM
flanders's Avatar
This is important^
Also follow the torque sequence from the service manual, think it starts from the middle cap then alternately front/rear.
