Cam sensor failure
Old Sep 7, 2010 | 07:18 AM
jared50438's Avatar
if you get a manual you can check the continuity between the plug and the ecu for the wires at the connector and the particular pins the corispond with at the ecu. ground, power,signal , or something like that. if you want to check what the connector should have.
Old Sep 7, 2010 | 07:51 AM
wadzii's Avatar
Banned
contact cleaner evaporates very quickly and is non conductive. perfectly safe to use on electrical components.
not all liquids are conductive.
Old Sep 7, 2010 | 08:01 AM
dales2000's Avatar
can this be done with a simple volt meter?
Old Sep 7, 2010 | 08:27 AM
wadzii's Avatar
Banned
yes
Old Jun 23, 2014 | 11:49 AM
almawa's Avatar
I am having the same problem, after I did valve adjustment on MY'04, happened the very next day after adjustment.
CEL would come on and RPM would drop over 3~4k like it was out of gas, and then bucking like crazy if I didn't let go the gas pedal.
I never had a chance to check CEL while I had that condition, cause CEL goes away after a bit, but the other day I did, got a P0344(CMP sensor bank a) and P0420 (could be Berk HFC and aftermarket O2).
So, I unplugged the Cam sensor on intake side and sprayed electrical cleaner on both male and female connectors.
Plugged it back in, but noticed connection was loose after doing a push-pull. This sensor connection is actually pretty difficult to properly seat.
There is a small stand-off on the the connector that is on the valve cover. Make sure that you get a loud "click", which means you engaged that little stand-off. Took me about 5 minutes to get it in, cause it's kinda awkward location, all the way in back of engine.
(that little thing at the top)
http://file.yoyoparts.com/oeimage/nc...3992122783.jpg
Hopefully it was just that connection. Will see if problem goes away.
Orleansjunky
Mar 26, 2018 05:51 AM
JEEBS
Mar 20, 2011 05:47 PM
Jermizzle
Aug 5, 2009 09:48 AM
WeezyBaby
Apr 3, 2007 10:45 AM
maticuss2000
Oct 24, 2004 07:39 PM
