HELP! CEL and 200 miles from home.
Old Mar 20, 2011 | 05:32 AM
JEEBS's Avatar
Default HELP! CEL and 200 miles from home.
So I'm in Vienna, VA after a 200+ mile drive from VA Beach. Whole trip was solid, no problems whatsoever. Last night I. Went to repark my car and my CEL came on. It wouldn't rev past 3k so I knew the car went into limp mode. No flashing CEL so I was a little at ease.
I went to AAP and the code is P0344 Camshaft position sensor - intermittant.
I guess my question is, can I make it home? I read a few threads and some have stated that it came back later, as in a few months. I just want to make it home and I will get my hands on the part then. All the parts stores up here don't have a cam position sensor.
Old Mar 20, 2011 | 06:03 AM
tweaks2k's Avatar
you will be fine just reset it and it should drive like normal.mine did this for nearly 8 months until i fixed it and some times i would just turn the car off and back on and it would rev on past 3k!
Old Mar 20, 2011 | 06:06 AM
JEEBS's Avatar
Did you just replace the sensor to fix it?
Old Mar 20, 2011 | 06:19 AM
tweaks2k's Avatar
yea i did but in my case for some reason it didnt fix it right away you just need to hook it up and clear the code with a scan tool and you should be fine!
Old Mar 20, 2011 | 12:40 PM
JEEBS's Avatar
Which sensor needs to be replaced? I looked at Majestic's diagram and there are two sensors listed.
Old Mar 20, 2011 | 05:47 PM
tweaks2k's Avatar
Yea there are 2 one for intake cam and one for exhaust cam...i belive that is the intake side. a or b should be givin when the code is pulled,A being intake and B exhaust.
2000silvers2k
Aug 25, 2016 09:02 AM
JEEBS
Mar 22, 2011 07:56 AM
sybar
Oct 27, 2010 01:03 PM
FREEK
Jan 9, 2010 01:20 PM
j8mie
Feb 13, 2008 11:53 PM
