Can someone verify my timing is correct?
Old Jul 29, 2017 | 08:55 AM
eld101's Avatar
Default Can someone verify my timing is correct? (pics inside)
See the pics attached. Not 100% sure I am on the right tick mark on the crank, but does it look like cams are good? Had the entire head removed and want a second set of eyes to make sure I am good... Next I am going to adjust the valves so I want this perfect. The manual looks like its saying TDC at the crank is the indent on the left, but some pics online are showing the yellow mark. Can someone advise??
Thanks,
Eric
Attached Thumbnails Can someone verify my timing is correct?-img_4917.jpg   Can someone verify my timing is correct?-img_4918.jpg   Can someone verify my timing is correct?-img_4919.jpg
Old Jul 29, 2017 | 04:25 PM
Slowcrash_101's Avatar
Looks fine to me.
Old Jul 29, 2017 | 05:14 PM
noodels's Avatar
Old Jul 29, 2017 | 05:18 PM
eld101's Avatar
Thanks guys.....now time to adjust my valves.....
Old Jul 31, 2017 | 02:10 PM
yamaha6611's Avatar
add on to this thread.... IF the timing was off by 1 tooth, how would the car run? anything extremely noticeable? mine is lined up like this but im still getting an intermittent "hiccup" at low rpms, when leaving a red light/stop sign.
Old Jul 31, 2017 | 03:42 PM
noodels's Avatar
I never want to find out,there is not a lot of piston to valve clearance anyway !!
Hick-up might be engine bay heat going into intake manifold,they don't like it one bit ! have a snorkel intake on mine and helps
Old Aug 1, 2017 | 05:35 AM
yamaha6611's Avatar
hmmm, im just trying to think of what could have changed when i did the retainers... it happened as soon as i did them.. everything runs/drives fine, lots of power, but im getting this little hiccup at low rpms.. .
Old Aug 3, 2017 | 08:36 PM
laserred02's Avatar
you're all set m8 ~
Spoolin
Jan 8, 2010 09:07 PM
Jacksparrow
Dec 7, 2008 04:05 PM
CaymanS2k
Jul 9, 2007 09:20 PM
Stratocaster
Sep 18, 2004 10:55 AM
1fastyellows2k
Sep 15, 2001 07:27 PM
