can't put it into gear.... help
Old Apr 5, 2010 | 11:48 AM
drhess06259's Avatar
Default can't put it into gear.... help
ok so i pulled the motor over winter and in doing so i left the clutch slave cylinder hanging and all the fluid dripped out over the prolonged period of time. so i refilled it and bleed it but now i can't get the car to go into gear????? could i have done something wrong??? it went into gear before the slave cylinder was installed.
Old Apr 6, 2010 | 10:05 AM
nothing????? y wouldn't the tranny go into gear?
Old Apr 7, 2010 | 04:27 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Air in the slave.
Unbolt the slave, point the bleeder straight up, and open it. Gravity will push the air out.
Dont run the master dry.
Trying to bleed the master by old fashoned method rarely works.
Old Apr 8, 2010 | 11:42 AM
ok so i did it again, I got all the air out the second i open the valve brake fluid comes out, the master never ran dry, i closed the valve. the car goes into gear when the car isn't on, but i can't get it into gear when the motor is running.
so i put it into gear and then tryed starting it even with the clutch all the way down to the floor it made the car jump like it is engaged. do you guys think i still have air in the clutch slave??? is there a way to check? the clutch pedal does feel funny, is there a way to adjust it or is it the slave?
Old Apr 8, 2010 | 11:53 AM
Billman250's Avatar
Top Answer: 1
sounds like you still have air in it. it should not feel funny.
Old Apr 8, 2010 | 12:17 PM
is there something i am missing??? I open the top of the reservoir and then open the bleeder screw, pump the clutch but i never get a solid feel until i close the screw.
I am not very good at bleeding brakes either lol. so all the help is appreciated. this is the last thing i have to do to get my car on the road after my build.
Old Apr 8, 2010 | 01:44 PM
ronnuke's Avatar
You do not "pump" the clutch pedal while bleeder valve is open. You are just introducing more air each pump while bleeder is open.
Do as Billman said and remove the slave cylinder from the side of the transmission while leaving the hydraulic line attached. (Just two bolts)
Then with the slave dangling by its hydraulic line, you position the slave in such a manner as to have the bleeder valve straight up and down, vertical so that all trapped air will go to the top where the bleed valve is. Then while making sure to not allow the clutch master cylinder to empty out, open the bleed valve and allow gravity to push out any trapped air. No need to pump the clutch pedal at all. HTH
Old Apr 8, 2010 | 02:12 PM
thanks for the extra explanation gunna go try that now.
Old Apr 8, 2010 | 03:43 PM
SilverS2kF22C1's Avatar
Also make sure the clutch slave is engaging the throwout bearing fork when you install it.
BigBang
Jan 18, 2016 09:39 AM
staylor725
Jan 16, 2015 02:29 PM
hyune_83
Oct 15, 2008 04:24 PM
Turbocanon
Mar 1, 2005 04:58 AM
