car problems, please help!
ok im having a lil problem with my car, it runs and drives but for the last 2 weeks i've been having a shaking problem everytime its in gear around 3-4k and i gas it. the rear starts shaking like crazy. do any of you guys have the same problem or even know what it could be? please pm me or reply.
thanks
david
thanks
david
If the vibration occurs under accel only then goes away under decel, it's most likely the inner CV joints.
If the vibration increases with speed and doesn't change under accel or decel. Tire balance, and checking for bent wheels is in order.
yea it just shakes when i accelerate then stop any other time. i havent even checked underneath the car. i was just curious if anyone has had the same problems. i was also thining it was the joint but i wanted to get a heads up.. thanks all. i will check them out tommorow.
anybody? i check it out today and it seems like there is lil bit of play from the axles to the differential. i dont know if thats common. i checked it out on my buddy's s2k and his has a lil bit of play but not as bad.
Originally Posted by dmpts2k,Mar 17 2006, 08:15 PM
anybody?
Checking the play between the joint and the diff won't tell you what condition the joints are in. There's always some play there. Do what Billman told you or do it the hard way and take the joints apart and inspect them.
