car problems, please help!
Old Mar 12, 2006 | 02:59 PM
dmpts2k's Avatar
Default car problems, please help!
ok im having a lil problem with my car, it runs and drives but for the last 2 weeks i've been having a shaking problem everytime its in gear around 3-4k and i gas it. the rear starts shaking like crazy. do any of you guys have the same problem or even know what it could be? please pm me or reply.
thanks
david
Old Mar 12, 2006 | 03:44 PM
xviper's Avatar
Have your CV joints inspected.
Old Mar 12, 2006 | 04:38 PM
Slows2k's Avatar
If the vibration occurs under accel only then goes away under decel, it's most likely the inner CV joints.
If the vibration increases with speed and doesn't change under accel or decel. Tire balance, and checking for bent wheels is in order.
Old Mar 12, 2006 | 05:57 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Really sounds like inner CV joints. you can swap them and not buy any parts. Search.
Old Mar 12, 2006 | 09:50 PM
dmpts2k's Avatar
yea it just shakes when i accelerate then stop any other time. i havent even checked underneath the car. i was just curious if anyone has had the same problems. i was also thining it was the joint but i wanted to get a heads up.. thanks all. i will check them out tommorow.
Old Mar 17, 2006 | 06:15 PM
dmpts2k's Avatar
anybody? i check it out today and it seems like there is lil bit of play from the axles to the differential. i dont know if thats common. i checked it out on my buddy's s2k and his has a lil bit of play but not as bad.
Old Mar 17, 2006 | 07:02 PM
xviper's Avatar
Originally Posted by dmpts2k,Mar 17 2006, 08:15 PM
anybody?
3 of us have already told you to target your CV joints. What else do you want to know?
Checking the play between the joint and the diff won't tell you what condition the joints are in. There's always some play there. Do what Billman told you or do it the hard way and take the joints apart and inspect them.
Old Mar 17, 2006 | 08:03 PM
Wisconsin S2k's Avatar
3 of the top mechanics on this site regarding S2000's tells you to check the CV joints. there's nothing more anyone can tell you. so, go get them checked.
Old Mar 18, 2006 | 11:24 AM
dmpts2k's Avatar
oh i didnt know they were..thanks for the help.
danielsun0922
May 9, 2014 06:51 AM
The Unabageler
Aug 25, 2010 03:01 AM
Oz2
Dec 24, 2008 01:00 PM
Dolemike
Jun 23, 2004 08:05 AM
BlueS2000
Mar 30, 2001 11:17 PM
