Car Stalling!
Old Jan 5, 2006 | 07:00 PM
mavericckk..'s Avatar
Default Car Stalling!
Just install: Comptech Intake/Spoon TB/Spugen Exhaust this past weekend. Drove for a week now for the engine to learn. CEL IS ON. CODE IS (P1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected) What should i do?Is the Spoon TB letting to much air in? All the Help is appreciated!!
Do i need a new Map?
Does a dirty PCV Valve have anything to do with it?
Did the following:
1. Reset ECU
2. Tap Map
3. Check all Vac Lines
4. Check Spark Plug
5. Check Battery
6. Check Throttle Cable
Thanks
B
Old Jan 6, 2006 | 06:38 AM
Cyclon36's Avatar
Did you check the wire harness toward the back of the engine next to the oil cap. If that's unplugged, your car won't rev past 3k rpms. I had it unplugged for a clutch job and forgot to plug it back in and had the same problems you have until I hooked it back up.
Old Jan 6, 2006 | 10:07 AM
Check..it....its all good...it might just be a new Map Sensor....
Day_One
Dec 28, 2016 01:20 AM
heymynameismark
Jan 2, 2016 05:13 AM
tdli
Dec 10, 2008 10:10 PM
Mirror
Mar 22, 2005 06:24 AM
RT
Jun 26, 2001 07:31 AM
