car threw a few codes the other day
Old Jun 25, 2010 | 08:31 AM
skurge's Avatar
Default car threw a few codes the other day
it came up as
p0411
p1415
p1416
i know the 0411 is the vac pump, all of that has been hooked up the same since i bought the car, so i'm not sure what the issue is there, i did go from a CAI to a short ram for the time being though....maybe thats the issue? the pump looks fine, as well as all the hoses going to/from it, the pump is turning on just fine, you can hear it just as always
car is running fine, doesn't seem to be any noises or anything so i'm really not sure what the other two codes are
anyone have an idea on the 1415/1416 codes? i'm at a loss
Old Jun 25, 2010 | 09:03 AM
suzuka-blue-s2k's Avatar
P1415 or P1416 is Air pump high or low voltage. So it all has to do with your airpump. Did you hook up the vacuum lines correctly when putting on that new intake? Switch them around, clear the CEL and see if it comes back.
Old Jun 25, 2010 | 09:30 AM
skurge's Avatar
i didn't change anything actually, i just took off the bottom half of the intake and put the filter on the shorter end
the intake is still the same as it was when i got the car 10K + miles ago
maybe i'll check the power wires and make sure its getting good power
Old Jun 26, 2010 | 06:29 PM
skurge's Avatar
anyone know if the kpro monitors this pump? can you ditch the pump if you get a kpro?
Old Jun 27, 2010 | 10:29 PM
jaundice's Avatar
Yes. You can ditch the air pump if you go KPro
rob-2
Apr 28, 2012 04:11 PM
crave13k
Oct 6, 2010 03:57 PM
superchrgds2k
Mar 17, 2010 03:49 PM
turbo_slug
Sep 17, 2009 05:37 PM
s2000honduras
Jan 23, 2006 10:17 AM
