Catch can install help
im about to buy a catch can, specifically the cusco can. does anyone have any pictures of where its mounted and how they routed the hoses?
also, i currently have the supra pcv mod on. if i decided to keep it, where would i put it and would it even be necessary with a catch can? im trying to reduce/eliminate the amount of oil im burning.
okay so with a bit of research this is what i came up with so far:
-run stock pvc into a vented catch can with a catch can breather filter
-plug the other catch can inlet
-plug inlet in intake manifold where pvc line used to vent to
if the above sounds ok, can anyone recommend me a vented catch can? i dont think the cusco can is vented?
1 Post
drill a hole...? lol i dont think it needs to be vented as long as it has the filter element since the air pressure is being pulled through your intake manifold.... only thing i know needs a vent is the radiator overflow
