Home Depot catch can
Old Jan 21, 2010 | 03:28 PM
wisdom's Avatar
Default Home Depot catch can
First things first:
This is how I plumbed it,
The arrow on the can that shows the direction of air flow is plumbed with the PCV at the back of the arrow, and the arrow is pointing to the hose that goes to the intake manifold
The PCV hose is routed to the inlet side of the can, then the outlet of the can is routed to the intake manifold.
THe can has caught oil, but there's oil in the return line to the intake manifold. I'm assuming that his isn't right because the hose to the intake manifold should be clear of oil.
Am I missing something? Comments, suggestions, experiences? I'll post some pictures when get home
Old Jan 21, 2010 | 03:57 PM
cheehee's Avatar
did you take the filter out of the catch can? how long is the hose between the pcv valve and the catch can?
Old Jan 21, 2010 | 05:18 PM
wisdom's Avatar
Catch can still has the stone filter in it.
Hose length is about 2 feet.
Old Jan 22, 2010 | 02:19 AM
s20009k's Avatar
did you make this catch can?
http://www.pbase.com/rsrock/image/33614056
Old Jan 22, 2010 | 12:44 PM
wisdom's Avatar
Yeah.
Old Jan 22, 2010 | 01:28 PM
superpirate's Avatar
I was in the process of putting this together as well but still need to find the right filter
Old Jan 22, 2010 | 01:50 PM
9K-S2K's Avatar
The mounting location is kind of strange. It looks pretty clean except for that aspect.
Old Jan 22, 2010 | 02:27 PM
wisdom's Avatar
What do you mean looking for a filter? This is a filter. It comes with a stone filter.
Yeah I didn't mount mine like that I mounted mine right infront of the fusebox.
Old Jan 22, 2010 | 03:37 PM
gospeedgo1's Avatar
I used the one from Lowe's without any issues. I have mine sitting in between the fusebox and throttle cable mount thing by the clutch and brake reservoirs
T da B
Mar 6, 2019 01:11 PM
Ek_Jak
Jun 30, 2017 02:39 PM
JackBeNimble
Sep 1, 2012 05:22 PM
rjbecker12
May 13, 2012 03:50 PM
dan_uk
May 1, 2010 11:39 AM
