CEL and bogging
Old Dec 4, 2011 | 07:42 PM
  #21
Mr._ap1's Avatar
Thanks for the link DFWs2k! With intense researching I've probably hit every link google's had regarding my codes lol!
Old Dec 4, 2011 | 08:10 PM
  #22
NFRAP2's Avatar
Originally Posted by Mr._ap1
So I finally researched and found out the firing order to our motor. #1 cylinder is closet to the radiator and it increases as you head towards the rear. (Checked all vacuum hoses and they were good and connected) Swapped coil #1 with #2 and the cel followed! Ah ha!! p0301 this time with the p1399 and no more p1410. I cleared the code and then I swap the coil (which was cylinder #1) that's misfiring to cylinder #3 but no cel still misfiring. With a little more driving, I hope to get a misfiring code for which ever cylinder the bad coil is currently plugged too. If so, mystery solved!
Cylinder number and firing order are two different things... the cylinders are numbered in order as far as the codes (p0301, p0302, etc.) are concerned, but the cylinders fire as follows:1,3,4,2. See This link Since the misfire followed the coil, I think you have your answer! Good luck and I hope that's the end of the issues and you can get back to enjoying your s2k
Old Dec 5, 2011 | 06:17 AM
  #23
Mr._ap1's Avatar
Thanks for the Link. Just to clarlify. P0302 is cylinder #2 misfire and I need to replace that coil right? I swapped the coil from cylinder #2 to cylinder #1 and the code went from P0302 to P0301.
Old Dec 5, 2011 | 07:00 AM
  #24
Reckon's Avatar
Based on your last post, it looks like the coil pack is bad. If the CEL followed the changing of the coil pack, than that is most likely the culprit.
Old Dec 5, 2011 | 07:34 AM
  #25
NFRAP2's Avatar
Originally Posted by NFRAP2' timestamp='1323061839' post='21210814
[quote name='Mr._ap1' timestamp='1323059779' post='21210746']
[/quote]
Yes, P0302 would mean that you need to replace the coil in cylinder #2 (assuming you swapped it back into cylinder 2 after testing it in cylinder 1).
Old Dec 5, 2011 | 10:47 AM
  #26
Mr._ap1's Avatar
Ok
Old Dec 6, 2011 | 02:45 PM
  #27
Mr._ap1's Avatar
Ok a quick update, I drove the car for 20 miles after clearing the cel and now the cel came back up with 6 codes from p0300 to p0304, p1399, and p0410. Would loose valves cause this?
Old Dec 6, 2011 | 05:17 PM
  #28
NFRAP2's Avatar
You mentioned that you have 100k miles on your s2k... have the valves ever been adjusted? If not, you need to adjust them anyway and then proceed with troubleshooting. You don't want to drive the car too much with it misfiring as it can damage your catalytic converter and will dilute your oil with fuel. Adjust the valves ASAP (search the forum and/or google for write ups) and let us know how the car is running at that point.
Old Dec 12, 2011 | 06:57 AM
  #29
Mr._ap1's Avatar
I did the VA and all were good except cylinder 3 exhaust was tight and cylinder 2 intake was very loose. I'm going to be rechecking the clearance again and would the motor be okay with the valve cover off till this weekend? (I did do a tight cover on the motor with a t-shirt)
Old Dec 12, 2011 | 07:05 AM
  #30
NFRAP2's Avatar
Yeah the motor will be fine as long as you have it covered so that nothing can fall/crawl into it.
