Cel P0411>>>>
Old Jul 16, 2004 | 12:01 AM
felonyruckus's Avatar
Default Cel P0411>>>>
P0411=Secondary Air Injection System Incorrect Flow Detected
vacuum hose?
secondary air pump perhaps?
anything else I should check to get rid of this CEL?
Old Jul 16, 2004 | 12:19 AM
dut's Avatar
dut
- hmm... third time this week?
- check these lines:
Old Jul 16, 2004 | 01:36 AM
I checked those dut, I tired it both ways one way definately is wrong because the car stalls. Therefore I am sure it is now correct. I still have the same CEL, I think I'm going to have to check the vacuum hoses carefully to make sure they are all in good condition. I might change them all just to be safe. If it's not the hoses...how much are secondary air pumps?
BTW I hear a high pitch whistling when I first start my car, then it goes away then it starts up again just during warm up though.
thanks for your time dut.
Old Jul 16, 2004 | 01:40 AM
Oh yeah, I like your direct port NOS set up. If Vtec is like a drug, Vtec + nitrous oxide=crack cocaine. I can only imagine the rush...
Old Jul 16, 2004 | 05:05 AM
Squeezer's Avatar
that whine is the air pump which runs for 60 seconds on cold start up, its perfectly normal.
Old Jul 16, 2004 | 07:56 AM
ahhh, thats what I was thinking, hoping(?) because it sounded like it had a purpose. I'm still trying to figure out what is causing the CEL though...hmmmmm...
Old Jul 16, 2004 | 10:58 AM
dut's Avatar
dut
- you did reset the ecu after switching lines right?
Old Jul 16, 2004 | 03:20 PM
yes i did reset after switching the lines
Old Jul 18, 2004 | 12:03 AM
UPDATE
Okay tonight I took my car out for a short but sweet drive. I noticed driving around in part throttle and then gunning it I could hear a bit of a whistle...so I guess its a vacuum hose I just have to find which. What do you guys think?
Old Jul 18, 2004 | 10:16 AM
Squeezer's Avatar
Originally Posted by felonyruckus,Jul 18 2004, 02:03 AM
UPDATE
yes sounds like a vacuum leak. try spraying all the vacuum lines where they connect with some carb cleaner. if you hear the revs drop, then that is the line that is leaking.
