cel po325
so i got a check engine light righ after i installed my clutch i made sure that all the plugs are conected right. i went autozone to get the check engine scan tool, and it shows as a po325, knock senson 1, what could this be?
your knock sensor is broken. If you check under the car it has a green cap andbits threaded right towards the middle of the block it has a green cap. Hit up the dealership and get a new one just make sure you have the right socket size to replace or u can jet do it with a wrench, that'll work too.
01S2KSA
15
Feb 17, 2011 06:55 PM
