CEL went on
Hmmm, I went down and took a look for it, but I can't see anything.... Does someone have another picture or can actually point it out? It is very hard to see anything below the intake manifold.
Originally Posted by Billman250,Jul 11 2006, 01:37 PM
If a clutch was done, it is very likely the knock sensor was cracked. It's very common.
The knock sensor is the line of fire when using a long extension to remove the upper starter bolt, which must be removed to get the trans out.
It's nice and hot under the intake, which makes the plastic sensor brittle. Bump it the wrong way with the extension = broken sensor.
i just had my knock sensor replaced and it is a little bit on the tricky side to replace. you really have to underneath the vehicle and reach over with a 24mm socket wrench. it is located on the driver side - engine block.
knock sensor problem causes the vtec not to engage causing a noticeable lack of power.
I drove it around the block and everthing was fine except when i would come to a stop the rpms would drop to 1 bar and than back to normal, It almost stalls. What is the reason for that?
j8mie
Feb 13, 2008 11:53 PM
