check fuel cap warning
Old Apr 17, 2015 | 07:19 PM
  #21
SweetWaterSurprise's Avatar
I'm going to try gas from another station that I normally would never go to and tighten as much on the outside as possible. I checked under the hood, under the car and in the trunk but see nothing out of the norm.
Old Apr 24, 2015 | 06:11 AM
  #22
Mijae007's Avatar
Mine only showed the blinking fuel cap light. No codes.
Old Apr 24, 2015 | 06:23 AM
  #23
Iniamyen's Avatar
I think this problem is only confusing because after correctly tightening the cap (helps to grip the outer ring) there is a time- or mileage-based reset period. I only had this problem once, but it took a solid 2 days to reset on its own.
Old Apr 24, 2015 | 09:25 PM
  #24
cosmomiller's Avatar
Top Answer: 1
There is a logic sequence for the ECU to determine an issue. I went through it a year ago so my memory is not spot on. The fuel tank has to be between a certain high and low point, you need to drive for 20 minutes, temperature is an issue, and I recall the speed must be some relative constant.
It is possible for another leak to be present and not just the fuel cap.
Old Apr 25, 2015 | 06:04 PM
  #25
I've searched but not been able to find any other leaks in the system
Old Sep 2, 2015 | 07:01 AM
  #26
CBR2000's Avatar
is there a way to check/clear the code with flashpro and a laptop? I got the issue for the first time yesterday evening, i have a MY06 and the odometer screen just displays "check fuel cap"
tudernos
Apr 2, 2009 09:47 PM
watchdogd
May 10, 2008 07:02 AM
fresh2k
Sep 12, 2007 06:23 PM
Mystiqueskillz
Jul 27, 2007 02:28 PM
Initial D God Hand WannaBEE
Mar 11, 2007 07:13 PM
