Clearing Electrical System
I'm still in break in and my friend, which was a former honda mechanic, told me that the ECU learns our driving patterns. So he said... since you drive under 3k the computer learns that, and adjusts timing for a slower driver and more fuel economy. He then said, when break in is over... to take off the battery terminal cables and place them together for like 15 seconds to clear out the ECU memory and start essentially from scratch. Is it ok to do that or will that harm something?
Andre
Andre
When he said that I got a little concerned because he's never worked on an 06 and the whole DBW System makes me a little nervous to mess around with the Electrical System. But I was also thinking... if it's bad then we can't change the battery. I would hope Honda would think about that.
Andre
Andre
Normally you only see a benefit from doing this in cars with computer controlled automatic trannies. The tranny will learn your less aggressive driving style and not downshift as fast or hold gears as long as it would if it were "trained" by an aggressive driver.
Kevin
Kevin
Andre
Andre
You may want to keep him as a "friend", but you really need to find a new mechanic.
Originally Posted by Emil St-Hilaire,May 1 2006, 03:51 AM
You can reset the ECU,anytime,and as often as you want;don't even have to disconnect the battery,just pull out the fuse,for a few minutes.
he has an 06. the pulling of the fuse can destroy the ECU if done at the incorrect time!
https://www.s2ki.com/forums/index.php?showtopic=340163
You must wait at least 15minutes after the key is turned off before unplugging the PCM. If you unplug the PCM while it's performing the SSD (self shut down) tests you can permanently damage the PCM
i</3speedbumps.
15
Oct 4, 2006 09:39 AM
