Click when braking in reverse
Old Feb 9, 2005 | 04:22 PM
b00stn's Avatar
Default Click when braking in reverse
Hey guys. Just noticed this the other day:
When I put the car in reverse or it rolls backwards (like on a decline) and I apply the brakes, there is a distinct click noise. It only makes one click and then stops. If I let off the brakes and roll a little more and then reapply the brakes, it does it again. Any ideas on what could be going on? Car is completely stock in regards to suspension/engine/wheels etc.
Thanks for any help
Old Feb 9, 2005 | 04:49 PM
joes sled 2000's Avatar
What you are hearing is called brake pad shift.It is fairly common amongst hondas.Basically the pads are shifting in the caliper from there normal position(in this case down) from the rotor going forward.When you go in reverse and apply the brakes the pad will shift up slighlty making this tapping or clicking sound.Nothing to worry about.
Old Feb 9, 2005 | 10:24 PM
lukemc01's Avatar
Wow- that's a relief. I've noticed the same before.
Old Feb 10, 2005 | 11:55 AM
b00stn's Avatar
No kidding. Thought I was going to have to take the car into the Dealer which is never a fun experience. Thanks for the info joes sled 2000
Old Feb 10, 2005 | 12:46 PM
USCdrifter's Avatar
I would also check to see if all the bolts are torqued properly. I had a rather loud click when I reversed and it turned out that I forgot to tighten the bolt that connects the caliper to the hub...I got a little too excited to test the new brakes...
Old Feb 11, 2005 | 08:52 AM
apex2k's Avatar
Check your hub nut torque. There is a TSB bringing it up to 220 and it includes your year. This one-click is a typical sign.
veehexx
Jul 13, 2010 12:57 AM
s2krazyyy
Jan 25, 2010 12:45 AM
qbmurderer13
Apr 29, 2008 10:15 PM
yosephs2k
Mar 19, 2007 06:59 PM
MaxGeek
Jan 8, 2005 02:13 PM
