Clicking sound,, help...
Old Feb 3, 2002 | 09:15 PM
Blk01S2k's Avatar
Default Clicking sound,, help...
When I am turning to the left.. going slow and making a wide or tight turn (such as a wide or tight circle) my car makes a clicking sound. with a patterns like Click..click..click..click.. the faster i make the circle the faster the clicking and vice a versa... almost as if "something" is hitting "something".. can you guys fill in the "something??"
Old Feb 3, 2002 | 11:18 PM
Schatten's Avatar
the differential perhaps?
clicking can be evident if:
- tire pressures are uneven
- fluid needs to be changed out (well, okay, its just a SWAG)
- diff blown
- other (unknown)
Old Feb 4, 2002 | 06:29 PM
Utah S2K's Avatar
I have yet to hear an S that doesn't "click" when performing a lock-to-lock U-Turn......and I've driven several. I'm pretty sure it is the diff (LSD) but I don't know of anyone who has positively isolated the sound.
Utah
Old Feb 4, 2002 | 09:57 PM
RT's Avatar
RT
To check diff, jack up rear (both sides), put in gear, release hand brake and turn each rear wheel both ways. Should be smooth on all four operations with the other wheel spinning the opposite direction. If you feel any Cap'n Crunch (w/ or w/o Crunch Berries) that's most likely your "something".
Old Feb 5, 2002 | 02:11 PM
Blk01S2k's Avatar
[QUOTE]Originally posted by RT
[B]To check diff, jack up rear (both sides), put in gear, release hand brake and turn each rear wheel both ways.
Old Apr 9, 2002 | 04:52 AM
funsdead's Avatar
I have this same problem. my problem
did you ever determine what it was....?
Old Apr 9, 2002 | 08:36 AM
Ajjra's Avatar
check the passenger side seatbelt is not hitting the door
Old Apr 9, 2002 | 01:12 PM
TriaXenginE's Avatar
something like that happened to me. i was driving to school when i heard my car go over something and then this clicking noise started to come almost immediately. when driving slow, it was less frequent, when driving faster it came with more frequency. i took it to honda and what they found was that i had run over a big bolt, not a nail mind you, but a BOLT and the thing was sticking out of the tire and made clicking noises as the top portion hit the pavement. when it rained the noise disappeared for obvious reasons. i had to replace the tire because the hole that it made was so big. luckily i didn't lose any tire pressure. so check that out, that could be it.
Old May 25, 2006 | 04:57 AM
us2bwrx's Avatar
blk 01 s2k, did u find out your problem? i have the same exact problem and im trying to figure it out, im pretty sure my diff is good, what happend with yours?
Old May 25, 2006 | 07:06 AM
Wisconsin S2k's Avatar
you do realize that when doing a steering wheel locked turn, that our diff will NATURALLY make some noise.....
also, clicking noises can be caused by so many different things. and often, the noise is a natural part of a noise the car makes. other times it's not. this is the main reason you see xviper/slows2k/etc avoid threads like these. you can spend hours upon hours looking for a problem that isn't really there. "noise" issues are difficult to diagnose over the internet.
S2k007
Feb 27, 2012 06:30 PM
PRB2000
Dec 30, 2009 09:19 AM
MR J
May 16, 2009 03:44 PM
Sparky
Nov 30, 2006 07:21 PM
Unicron
Jan 21, 2003 03:13 PM
