Clicking sound from the rear.
Old Oct 15, 2003 | 08:03 AM
SuperDyu's Avatar
Default Clicking sound from the rear.
Recently I've had problems, with my car.
Specifically, when I go over small bumps or potholes there is a very noticable knock/rattlying sound from the rear driver tire. The ride quality is a little rougher on the driver side (I think). It's more noticable when in cold weather (even if the engine is warm). Some mentioned it might be a spacer between the spring.
It won't come up on things like speed bumps, but over potholes, uneven road, man holes (even if flushed) it is very distinct. Several people in the passenger side have also confirmed that it's from the rear driver side of the car.
I already checked the bolt on the spare tire (someone suggested this on a club forum) and it's ok there.
I'm sure I'll bring the car in to a dealership to be checked out but I'd like to have some sort of idea on what it might be so I don't get shafted (The car only has 3000 miles on it, so whatever it is it should be under warentee).
Any help would be appreciated.
Old Oct 15, 2003 | 01:15 PM
rocketman's Avatar
I had a problem with a noise from the rear tire that I describing as a "ticking" sound. I did a search on the forum for "ticking sound" or "ticking" or "ticking noise". I can't quite tell from your description if it is the same problem I was having, but it sounds similar. I was actually able to find a "tech note" (I don't think it's a TSB) someone posted.
If I remember correctly, my problem was a loose pinion nut and the fix is to put a new nut on (the old one wears unevenly or something); when I took it in to the dealer (the good dealer, not the moron dealer), as soon as the mechanic heard the sound he know immediately what it was.
Good luck.
Old Oct 15, 2003 | 01:52 PM
SAIYAJIN's Avatar
Try changing your diff fluid. I had the same issue and it went away as soon as I changed the fluid. Do it especially if you've recently installed a gear set.
Old Oct 16, 2003 | 12:44 PM
SuperDyu's Avatar
Well the car is stock with only 3000 miles... I would hope they gave it to me with full fluids.
Old Oct 16, 2003 | 05:16 PM
Scott F's Avatar
If it is happening when you start and stop, it would be the axle nuts. Your dealership will replace the nuts and grease them. I had the same problem.
Old Oct 17, 2003 | 12:54 AM
Silvers808's Avatar
what i did was loosen the axle nuts and retorque them to 220ft lbs.
no more clicking
Old Oct 17, 2003 | 03:51 AM
SLAPMYFRO's Avatar
[QUOTE]Originally posted by SAIYAJIN
Old Oct 17, 2003 | 06:21 AM
SAIYAJIN's Avatar
I changed it when I installed gears and about 1 month after installing the gears.
Shigun
Jun 28, 2015 09:01 PM
AeroS2000
Jul 22, 2008 06:59 PM
Blitzkrieg
Apr 15, 2007 06:34 AM
Xistence
Nov 10, 2006 12:05 PM
rustywave
Oct 9, 2005 07:32 PM
