Clunk/Knock at sudden acceleration
Old May 28, 2014 | 08:29 AM
Chris_Lum's Avatar
Default Clunk/Knock at sudden acceleration
I have developed a clunk from the rear end upon sudden acceleration. I’ve noticed it in the following situations:
1.When crusing at steady speed, if I jab at the throttle and make the car lunge a bit, it’ll make a single clunk/knock noise.
2.If I lightly launch from a stop (take off from maybe 3-3.5K rpm), it’ll make multiple clunking noises—about 2-3 clunks/knocks.
Note 1: It is a clunk/knock noise, NOT a sharp click noise. I’ve already done the Axle nut retorque to Billman’s NEW spec, using a huge ¾” drive 3 foot breaker bar. I’ve not had the clicking since, so I’m fairly certain the axle nut issue is solved. Also it is a completely different noise. One thing to note is, I drove around with the clicking for over a year, so I hope there wasn’t any permanent damage to my wheel bearings. Any way bad wheel bearings or not fixing the axle click for a while would create this type of knocking noise?
Note 2: Changed diff fluid last night (Old fluid was 14K miles old). Using Motul 90PA, old fluid was clean with no metal shavings.
Note 3: Diff mounts look fine. I've changed the notorious driver-rear diff mount last year since it busted. Last night while doing the diff fluid, I did not see any more busted mounts.
I’ve research UTH and found this post by XVIPER on a very similar thread: https://www.s2ki.com/s2000/topic/269...1#entry5107677
Originally Posted by xviper
A loud clunk as you describe upon deceleration can mean one of many things. It could be a bad CV joint in the 1/2 shafts, a bad joint on either end of the prop shaft, a bad diff, a bad diff mount or loose suspension component. Diagnosing which one of these it could be, will be the challenge.
Anyone know how to check CV joints and the prop shaft for bad joints? Is there a way to check them without disassembly?
Old Jun 10, 2014 | 09:01 PM
Chris_Lum's Avatar
Solved my problem: Both engine mounts were torn. replaced them both with new OEM mounts and clunk is gone!
aw11
Sep 29, 2018 06:48 PM
Floppy
Jul 14, 2015 01:39 AM
KyungMin
Feb 13, 2014 04:13 PM
veehexx
Dec 14, 2010 03:59 AM
Plastic Sith
Dec 20, 2008 03:52 PM
