Clutch clunk in reverse
Old May 9, 2001 | 07:30 AM
Samurai's Avatar
I've started to notice a "clunk" sound when
pushing in the clutch when driving in reverse.
I haven't noticed the sound in any forward
gears.
Anyone else experiencing this? Is this normal?
-Samurai
Old May 10, 2001 | 07:54 AM
Spaboy#5599's Avatar
Hey I do experience the problem as well, everytime i am in reverse only the clutch does make a clunk sound im am not sure is this is normal either.
Old May 10, 2001 | 08:54 AM
SeattleSilver's Avatar
I notice a clunk as well but it seems to be coming from the rear of the car, I not sure if its the clutch or something else, parking brakes releasing possibly?
Any gurus in here know?
Old May 10, 2001 | 09:17 AM
Wesmaster's Avatar
I get some nice clunks with the transmission at low speeds when I shift in a and out.
Wesmaster
Old May 10, 2001 | 06:19 PM
s2k_scott's Avatar
I get some serious clunks (can feel it through the seat) when coasting at slow speeds and shifting in to 2nd or 1st. Anyone else?
Old May 11, 2001 | 09:07 AM
Driver's Avatar
Yeah I get'em to, I thing it's normal this thing
is like a race car it's got a racing tranny
it's gonna be noisy!
Old May 11, 2001 | 12:45 PM
Silver Bullet's Avatar
I've noticed the same thing but it's only happened about 5 or 6 times since I've had the car (a little over a year). My clunk sounds like it's coming from the right rear area.
Old May 11, 2001 | 04:38 PM
ultimate lurker's Avatar
If you get a clunk or click while in reverse, after backing up and then hitting the brake (which usually comes around the time you disengage the clutch), that is the rear brake pads shifting a bit. Nothing to worry about. Usually only happens to me first thing in the morning when the car is cold, so once the pads heat up apparently whatever clearance there is goes away.
UL
Old Nov 14, 2002 | 04:03 AM
cerberus264's Avatar
If it happens only in 1st or reverse when you release the clutch and the car takes up drive and you can repeat it every time, then you may find it is to do with the CV joint cup. There are loads of posts if this is the case. Do a search on 'clunk' or 'drive' and you'll see what I mean.
Mine is going in next week for some stuff to be done and the technician is also going to look at this for me.
Old Nov 14, 2002 | 09:37 AM
cyk's Avatar
cyk
I get the clunk when putting in 1st gear.
It's very similar to putting a motorcycle in 1st gear from neutral...but don't know why the s2k is like that...
Shifting to 4th gear (without letting out the clutch) before shifting to reverse will take away the clunk. If that's the 'clunk' or grind like sound, some of you are talking about.
