Clutch fluid disappearing ?
Old Jan 9, 2016 | 01:11 PM
FRSKLLR's Avatar
Default Clutch fluid disappearing ?
So the first time I noticed this was a little over a month ago. The transmission started having a harder and harder time getting into a gear until the point where I could not move it out of neutral. When we checked the clutch reservoir, there was little fluid and what was left was pretty dirty. For the sake of getting the car mobile again I filled it back up with the correct fluid. Yesterday it did it again. I would think it is a leak but no fluid can be found under the car. Any recommendations? I'll try and upload a photo.
Old Jan 9, 2016 | 01:42 PM
noodels's Avatar
Could running down clutch pedal inside car
Old Jan 9, 2016 | 02:08 PM
zeroptzero's Avatar
^ This. Has your left shoe been getting stains on it ? , lol. The fluid can leak out of the clutch rod cylinder and it comes down onto the carpet by the dead pedal under dash. The other location that can leak is the slave cylinder under the car on the drive side of the tranny.
Old Jan 9, 2016 | 03:21 PM
Soviet's Avatar
Check for a leaking clutch master cylinder by looking at the firewall, under the dash. Very common leak on our cars, especially when the clutch fluid isn't changed regularly.
Old Jan 10, 2016 | 01:42 PM
clio's Avatar
If it's leaking down the clutch pedal get a turkey baster / syringe and suck it all out of the master clutch cylinder. Then get some paper towel and clean inside it to get rid of all that black gunk. Fill it back up to spec. Quite often a leaky master cylinder can be fixed with just this procedure.
Also have the clutch system bled.
Old Jan 10, 2016 | 03:03 PM
FRSKLLR's Avatar
It was in fact leaking here so I'll have to do this, thanks! Thanks everyone else as well
Old Jan 10, 2016 | 03:10 PM
noodels's Avatar
Old Jan 11, 2016 | 12:32 PM
Trustd_1's Avatar
keeping the fluid clean will help prevent leaks and extend the master cylinder's life. the s2k's CMC is prone to leaks if not regularly maintenance.
Xeon
Mar 6, 2021 03:27 AM
acn684
Aug 16, 2011 09:36 AM
hellspare
Jan 12, 2010 01:34 PM
LNKs2k
Jan 10, 2009 04:59 PM
ahrmike
Sep 11, 2008 12:03 AM
