Clutch Fluid/Hydrolics and affect on Clutch
Old Aug 16, 2011 | 06:04 AM
acn684's Avatar
Default Clutch Fluid/Hydrolics and affect on Clutch
Can someone explain to me how old clutch fluid and or leaking cmc's affects how a clutch is released properly or not?
The notchy shifting is coming back for me, i've changed the shifter and lubed it up already. Doesn't seem to be the trans oil. I had the fluid flushed a month ago, seemed to help but the notchiness came back. I suspect it might be a leaking cmc leak (there's black gunk where the rod meets the cylinder but its not like its "leaking (dripping)"
Maybe if I understood the mechanisms of it better, i might go and replace some of these parts/flush out the fluid again.
Old Aug 16, 2011 | 08:52 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
As the master crosses dirty fluid, the disengagement becomes less.
Change the clutch fluid. no need to flush and bleed it. Just suck out the master, clean it ourt with paper towels till spotless, and fill it back up.
Your leak will stop.
Old Aug 16, 2011 | 09:36 AM
acn684's Avatar
What do I do with all this gunk on the cmc rod?
FRSKLLR
Jan 11, 2016 12:32 PM
robrob
Dec 29, 2012 07:31 AM
LNKs2k
Jan 10, 2009 04:59 PM
ahrmike
Sep 11, 2008 12:03 AM
Gernby
Nov 1, 2002 05:51 AM
