clutch fork "hook" broken
Old Jun 25, 2014 | 08:50 AM
Cgb569's Avatar
Default clutch fork "hook" broken
While driving the other day I noticed the clutch pedal get significantly harder to depress, but the car still shifted fine. I figured it would be a good idea to turn around and go home to check things out. As soon as I got the car turned around the pedal would no longer move at all and the car would not shift unless turned off. I took the slave cylinder off to check things out and I noticed the hook that the clutch fork rests in was broken near one of the bolts. I have not yet removed the trans to check things out.
Could that broken part be the problem? Or could something else have caused the pedal to get super stiff and the hook just broke because I was pushing it hard to try to shift the car?
Thanks for any tips.
Old Jun 25, 2014 | 04:01 PM
_brandon's Avatar
What most people will say is tear it apart and investigate. Sadly as far as I know clutch forks can only be installed with the transmission off. So guess what you might have to be doing..
Take a pic too of the damage for more help!
Old Jun 25, 2014 | 04:29 PM
iDomN8U's Avatar
The fork clips in from what I remember.
You can remove the fork from the clip but it still remains partially inside the transmission.
I did that in order to grease the spline and fork tips
Old Jun 25, 2014 | 04:31 PM
iDomN8U's Avatar
If the clip is broken, yes you cannot disengage the clutch
Old Jun 26, 2014 | 03:04 AM
dc2-2-ap1's Avatar
This happened to a friend's car a few weeks ago. Replaced the hook, spring, shift fork and throw out bearing (also replaced pilot bearing and clutch disk, but those aren't related to the problem). He hasn't had any problems since.
Old Jun 26, 2014 | 03:22 AM
Cgb569's Avatar
Yeah the clip is broken. Im working on getting the trans out right now. I will post pictures once its out. Thanks guys
madcowdk
Dec 27, 2015 01:38 PM
drobinson1692
Apr 29, 2013 03:55 PM
Urban_Monkey_One
27
Feb 1, 2011 09:26 AM
jdm_rsx
Sep 27, 2009 07:58 PM
PalenkosBro
19
Jan 18, 2009 05:21 PM
